Not showing "Vraymtl" as option in materials edito
  • Not showing "Vraymtl" as option in materials edito
    I recently downloaded the version for 3dsViz4 (VRay free 1.09.03m)(Vray40.dll) and for some reason when I go to the materials editor and try to select the VrayMtl, it isn't even showing up as an option. What is going on here?
    I did assign the default renderer to Vray free 1.09.03m (both production and draft)
    I did check in the options of the materials editor and set the current renderer to VrayFree.
    The VrayShadow is working correctly, but nothing shows up under the Materials Editor that resembles Vray (VrayLightMtl, VrayMtl, etc.)
    Any suggestions, and is the best version to work with 3dsViz4???
    there is no vraymtl in vray free only in the advanced version
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      So is the advanced version the one that you have to purchase? If so, then why wouldn't they let you try the materials?
        if you want to try the materials. Get the demo, it has everything but is time restricted and you cant save any vray settings.
