I am using V-Ray 5 for Maya on a Windows machine, then rendering remotely on a Linux machine. I began to notice inconsistencies between the colors/lighting in frames rendered on my Windows machine vs. on the Linux machine. I believe I have traced the issue to my Linux machine not being able to use the config.ocio file, so it defaults to raw as the input color space. I have attached a screenshot of the display correction settings in my V-Ray Frame Buffer on the Linux machine. My OCIO env variable is set. Clicking the blue dropdown arrows on Input Colorspace, Display Device, and View Transform does nothing.
Is this an OS issue? Or is there a specific way someone is aware of that you need to configure ACES to work on Linux machines?
Thank you!
Thank you!
