Could not obtain a license (-7): -7: The Chaos License Server is denying access.
  • Could not obtain a license (-7): -7: The Chaos License Server is denying access.
    Could not obtain a license (-7): -7: The Chaos License Server is denying access. Update the license server and check access filter (if any).
    Hello I'm having trouble getting Vray to work on my new computer after installing it. To make things worse I accidentally turned on borrowed licenses & now I can't turn them off.
    I've tried going to the license server activation & dropping in the cert, but it's a .CRT file & it says "File is not valid!" because it never gives me a .csr
    I've uninstalled & reinstalled the license server several times. The license server never gives me an option to log in & add an activation key or anything.
    I can't deactivate the borowed license as it says "the server has borrowed licenses and cannot be deactivated
    This process is very confusing. If anyone can help, thank you
    If that is Windows (and it looks like it is) follow the steps in the attached PDF file.
    Kostadin Botev
    Contact Support
    Chaos
      Hi, I'm actually having the same problem on a mac (c4d r26 macos x monterey) any pdf for me?
        Here you go.
        Kostadin Botev
        Contact Support
        Chaos
          Thank you very much, you saved my day
