Having issues with "Show Shaded Material in Viewport"
  • Having issues with "Show Shaded Material in Viewport"
    Having an issue with the color correct node and show shaded material in viewport.
    The images I attached are showing the bricks material from the vray library. As you can see if remove the color correct node I can't get he image map to show in the viewport again. Even if I simply add it back in.
    I can recreate this issue when I make a material from scratch using any image map. Adding or removing the color correct node has the same result as the screen caps I provided.
    Am I just doing something wrong or is this a bug?
    My apologies. I could have swore I posted this in V-Ray for 3ds Max :: Issues.
    So I am assuming I am doing something wrong then? No one else has this issue?
      Just tried this and it works ok for me in 23. There was an issue with 'show maps..' but it was fixed in a very recent update...maybe that's it?
        Thank you fixeighted! I did not see there was an update on March 16th. This fixed it!
          Yay! That's 2 good deeds in one month....I need a break
            We need to give you a raise.
