Mesh Smooth - rendering irradiance map taking so long
  • Mesh Smooth - rendering irradiance map taking so long
    Hi everyone, i have noticed that when im rendering scene full of low poly objects with mesh smooth modificator it takes me a significantly longer time than the same scene with the same objects but converted to meshes. Is thar any way i can use low poly objects with MS mod and have the same time of rendering ? because when im changing objects to meshes i loose capability of change shapes...
    renton
    scene state manager?
    I dont know, but maybe works. try it on a separeate scene.
      try vrays meshsmooth and see if its quicker. i dont know, i havent done any comparisons
        woah, wait... Vray MeshSmooth?... when the hell did that happen?
          Try turbosmooth instead of meshsmooth
            yup. its part of vrays displacment
                Just use subdiv mode in vray displacement (2d, 3d, subdiv) and dont have a map (Set amount to 0). That way the only thing its doing is what meshsmooth would otherwise do.
                  @ duke 2
                  Many thanx
