Walls always grey
  • Walls always grey
    No matter what settings I enter I always end up rendering out these grey walls, then I want them to be a crisper white. Does anyone else have this issue?
    For a white wall you can start from something like 80% grey value, once your lighting/camera setup is correct you need to tune the tone mapping in the VFB, you can start with an highlight compression and use a photographic LUT or a filmic tone mapping to get a nice white wall while retaining a good contrast.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      White is one of the hardest things for me. I can almost never get it in the frame buffer, so I take care of it in post.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        Hi Bobby, you can get good white out of the VFB, here is an example, 80% white plaster, then just highlight compression and a LUT. Don’t forget that like in real life lighting, windows, and materials affect the result a lot, for example it will be very difficult to get the same white if your room have small windows, the sun in a different position, dark material on floor etc.
          Nice! What LUT are you using?
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Kim Amland photographic LUT
              Most problems with having nice whites, come from unrealistic values for diffuse / albedo, wrong lighting and camera setup. Using real world values and as Sirio suggested an 80% grey value should get you the results you're after.
              A.
              www.digitaltwins.be
