Rhino to Max vray material
  • Rhino to Max vray material
    Hi All
    I know you can export vrmat for Rhino but can you import Vrmat into max ? It looks like you I have to make the materials agin? any work around for converting a vrmat to mat so so I can import my rhino vray materials in max then use with corona or vray cheers
    Hi. We have a VRayVRmatMtl node in Max. You can use it to load your saved material from Rhino and render it in V-Ray.
