Anima axyz - Running on spot/ running machine
  • Anima axyz - Running on spot/ running machine
    Hello,
    We have the full anima subscription and creating a gym animation.
    I cant find one, but has any one come across in the library of people a 4D person running on the spot that could be put on a running machine.
    or is there anyway to get the rigged character to run on the spot?
    Many Thanks
    Hello william.morris,
    Thanks for your message.
    One of the options available on the new 4D walking models is the ability to make them move “in place,” without applying any translation. That has been a feature much requested by users who often populate gyms with treadmills. Now you can do that by dropping a 4D walking model outside its path and then activating the “move in place” option as you can see in the following example video:​
    Alternatively, you could also do it on Rigged models by downloading a running (or similar) animation from Mixamo with the "In Place" option enabled and then import that animation in Anima and set it up as a standing animation. In the links below you will find more information about this process, but please note that these articles explain how to import motions with the "in place" option disabled, so keep in mind the difference:​
    If you need more information, please let me know.
      Hi Albert,
      Thank you very much, that is exactly what I am after!!
      The Mixamo motions are also amazing, as that answers another question I had, which was to get a character to swim!
      Much appreciation for the reply!
        Can Chaos add a separate section on the forum for Anima? We always have quiet a few questions but finding the info is a nightmare when looking at at the technical docs. They are often pretty generic and it just doesn't state what you need to do in some instances and are left to just guess and search within the program or even worse, use the facebook group page.
