Yet another OCIO config - with an unusual but in my opinion perfectly suited for cgi display transform from RED (the camera people. because of that you will need to download some luts on your own to make the config work).
It offers 16 combinations of contrast curve and highlight rolloff plus RED Creative LUT Kit as OCIO Looks (this at the moment is supported only by Vantage).
One thing worth pointing out is OCIO file_rule: - !<Rule> {name: ColorSpaceNamePathSearch} - instead of renaming files to make 3dsMax recognize appropriate colour space for the texture this rule reads the whole file path so for example a subfolder with a string "acescg" that contains the texture file. Seems to work in 2024 with native Bitmap node (so I guess also with CoronaBitmap).
apart from RED transforms it has ACES 2.0 rev060 and original AgX as fallback to something more common.
CGI OCIO config 04
CGI OCIO config 04
