VRAYHDRI Map visible in viewport?
  • VRAYHDRI Map visible in viewport?
    Hello,
    i´m a vray newbie and have a problem.
    I use 3ds 9 an vray 1.5
    I use a vrayhdri map for environment and as map for vray domelight.
    Is there any possibility to make the environmental map visible in the vieports?
    I try to use it as environment map for max too, but the hdr is only in the rendering.
    But i need it visible to arange my model proper to the hdr.
    I hope you understand my problem.
    And yes i used the search function
    Greets
    Map it into a sphere with a vray light material and turn it on in the viewports instead - you can use the light material multiplier the same way as your environment or domelight multiplier.
      Thanks for your answer, this solution works.
      Now I have to test ift the lighting wit the Light material is still the same as the domelight wit h the HDR Map.
        The dome light has a few tricks built in to it to make it cleaner and quicker than using the sphere method but as you say it's less easy to align.
