DMC sampler noise warning
  • DMC sampler noise warning
    Hello,
    anyone know how to turn off this warning message:
    "This file was created with an older version of Vray render. The DMC sampler Noise Threashold perameter may need to be increased to get same results..."
    1st- the ver of Vray is 1.5 for max 2008, and it's been saved as such many times.
    2nd this message comes up on all the network server nodes and stops the network render job (as it requires a return to continue).
    thanks,
    Billibong
    install 1.5 SP1 if you can afford to do this during this stage of your project. will that work? anybody? clever people?
    Kind Regards,
    Morne
      you should also ask for full forum access so that there is no confusion over your vray status
        Is sp1 a newer patch for vray 1.5 for 2008?
        I have 1.5 for max 2008 (32 bit) demo installed.
        Does sp1 superceed this version?
        Thanks,
        Billibong
          according to what your saying and what i know of the demo its very strange that the demo would work as your saying. unless of course the restrictions on the demo have been removed
            The audacity!
