Vray RPC bug
  • Vray RPC bug
    Hi all,
    I'm a official vray customer but I don't understand why I can't post a new thread on Vray-problems thread.
    Only beta tester can post bugs?
    Ok.
    With Vray 1.50 SP1 I found a bug using RPC on Max9 64 and Max2008 64
    If you have an animated vraycamera with a extreme wide angle lens RPC people disappear if they are intersecting the screen border of render window, they appear only if the camera looks them approx in the center of the screen.
    If you want surpass this tedious problem you have to activate the reflection RPC parameter on each RPC object.
    Regards
    Gabriele
    no idea about rpcs, but as long as posting goes you should mail to chaos providing them your customer login and which forum user you'd like to have activated.
    http://www.chaosgroup.com/forums/vbu...ad.php?t=29088
      Sounds like an RPC problem to me and maybe not a vray problem ..
      Natty
      http://www.rendertime.co.uk
        I remember this might have something to do with perspective correction, try setting perpective correction/vertical shift to 0 and see if that gives proper results. Or switch between Standard Camera and VrayPhysicalCam to see it that helps.
        For a single image perspective correction can be done in post, for an animated camera i wouldn't use it at all.
        Ruud
        3DV - Ruud van Reenen
        www.3dv.nl
