It just arrived. I think there should of been instructions for what to do next. After searching, I found out that I'll get the drivers for the dongle in the same file with vray, but it doesn't say whom to contact in vray, and how to download everything.
Bought the license dongle...no instructions
There are installation instructions in the help index here:
http://www.spot3d.com/vray/help/150S..._quick_1_5.pdf
If you need any assistance, please email us to vray@chaosgroup.com or call us on any of the numbers listed on our web site here:
http://www.chaosgroup.com/en/2/about.html
VladoI only act like I know everything, Rogers.
Upside down as in the last post is on the bottom?
That is the default setting and usually how you read...
But you can change it in your User CP under Options. There's a Thread Display Options section with a pulldown that's set to "Linear - Oldest First". You can set that to "Linear - Newest First".www.artbyarjan.com - Online portfolio (temporarily offline)
@home:
/ AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
/ Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
@work:
/ Intel Core2Quad Q9450 @ 2.66Ghz / Nvidia Quadro FX 3700 / 8Gb Ram /
/ Vista Bussines x64 /
I'm used to forums having the first post on the top. On this forum, when I want to read the thread, I have to open it, than go to page two, or whatever page is first (last) then, on that page scroll to the bottom and then read up. Maybe it's logical to have the last post on the top but it's not practical. Thanks, I'll see in CP what I can do.www.hrvojedesign.com
A "trick" I always use, is this button:.
It takes you to the last unread post in a topic.
But I think your CP settings are wrong, because for me, the first post is on page 1 and the last post is at the bottom of the page.
So the settings in your CP should be set to "Linear - Oldest First"www.artbyarjan.com - Online portfolio (temporarily offline)
@home:
@work:
