Vray Proxy crash
  • Vray Proxy crash
    I use Vray through work (1.5 Sp1 on Max 2008 32 bit).
    I've had problems exporting vrmeshes (onyx trees; dosch cars etc) and noticed that this was fixed by converting all materials to vray materials.
    Might be worth noting - vray sp1 doesn't like exporting vrmeshes with non-vray materials (like raytrace)
    OK thanks.
    There is an issue rendering VRayProxy objects with a Raytrace material applied to them; this is a known issue, but it looks like it is not possible to fix this easily.
      I'm not familiar with the limitations of the free version of VRay, but you should avoid using non-VRay materials at all costs! They're a little slower, bounce light incorrectly, and can cause general mischief.
        why sp1?? and you should really register on the forum so that you can get full access. just send your purchase order information to the chaos guys
          OK thanks.
          How do I operate the CD stacker in your car that I just stole?
          ..see what I did there?
