SDK: Writing Specular/Diffuse Informations to render elements
  • SDK: Writing Specular/Diffuse Informations to render elements
    I am writing an own small shader to do some basic stuff and have one big problem.. I am calculation the diffuse, specular and ambient color in the eval() method and am returning the combined color.
    That's working fine and looks right, but as soon as I add some render-elements to get a specular pass for example, the result of my material looks wrong in this element.
    But that's right too, because how should VRay know about my specular-values? I am not passing them to VRay anywhere.. only the combined result color.
    So, how can I tell VRay what color to use for the specular-element-pass?
    Thanks,
    Aya
    V-Ray will automatically add the diffuse and specular results, but you must check the flags passed to BRDFSampler::eval() for the FBRDF_SPECULAR and FBRDF_DIFFUSE options, and just compute the required component.
      ah okay, thanks
      And is there a way to write something to an own render-element?
      For example, create a render-element called "Fancy stuff" and have my material put some fancy stuff in there..
      Aya~
        Yes, you can do that. When you create a V-Ray render element plugin, you need to define an "alias" for it; after that, in the traceForward() method of your BRDF, you can write to this element in the following way:
        Code:
        VR::Fragment *f=(VR::Fragment*) rc.mtlresult.fragment;
        if (f) {
          VR::Color someColor(0.5f, 0.5f, 0.5f);
          f->setChannelDataByAlias(myElementAlias, &someColor);
          Thanks a lot
          One last question... there's an "VRay_SelfIllumination" RenderElement.. how can I write to this one?
          Aya~
            It should work if, in the code above, you replace "myElementAlias" with "REG_CHAN_VFB_SELFILLUM".
              This is how my traceForward looks now:
              void MyBaseBSDF::traceForward(VR::VRayContext &rc, int doDiffuse)
              VR::Fragment *f = (VR::Fragment*)rc.mtlresult.fragment;
              if (f) {
              VR::Color color(0.5f,0.5f,0.0f);
              f->setChannelDataByAlias(REG_CHAN_VFB_SELFILLUM, &color);
              But it's not working.. the VRay_SelfIllumination is still black
              Do I have to call traceForward myself somewhere?
              Aya~
                If you put a breakpoint in the code, is it reached?
                  umh, it was my fault.. forgot to assign the material xD
                  But do I need any special default implementation for the traceForward()?
                  Because if I just add the traceForward()-function in my code without anything in it:
                  Code:
                  then my material looks a lot lighter (or transparent).. how comes this?
                  Aya~
                    Be sure to call the default implementation BRDFSampler::traceForward() before or after your code.
                      Ah okay, it's working now
                      Thansk~
