SDK: Normals and BumpNormals
  • SDK: Normals and BumpNormals
    how do I set my BumpNormals, so they are outputted in the BumpNormals-RenderElement?
    Or do I just write them manually in the traceForward()-method?
    Aya~
    Yep. This is what VRayMtl does also. V-Ray itself is not aware of what normals you will be using in your material.
      Okay, but then I have an other problem..
      I wrote the material using Vray Sp2 for Max 2009.. I transformed my normals like this:
      Code:
      VR::BSDFSampler* VRayScanlineMtlBase::newBSDF(const VR::VRayContext &rc, VR::VRenderMtlFlags flags) {
      		Point3 bumpValue = bumpMap->EvalNormalPerturb(sc);
      		bumpValue *= ((float)bumpStrength * 0.005f);
      		sc.SetNormal(FNormalize(sc.Normal() + (sc.backFace ? -bumpValue : bumpValue)));
      //[... other BSDF Init Stuff]
      and it works all fine.
      But in Sp3 now, when I connect an VRayDirt to my Diffuse-Color-Channel, the dirt is ignoring my normal-transformations... in Sp2 it's working, in Sp3 not... why? What's the difference?
      (With a normal Max-StdMaterial it's working in both.. Sp2 and Sp3)
      Aya~
        I'm not quite sure, but you have the sources of VRayDirt in the SDK, so you can debug it and see what happens.
