SDK: eval() and GI
  • SDK: eval() and GI
    if I enable GI for rendering and add a RenderElement "GlobalIllumination", I get the GI in the renderElement but not on my BeautyRGB..
    How do I handle the GI in the eval() or any other function to add it to my final-output-color?
    Aya~
    Are you writing a material? This will be done automatically if you call VRenderMtl::shade(). You need to make sure that getDiffuseColor() returns the proper color of the surface.
      Yep, I am writing a Material.
      Should getDiffuse() return only the color that will end up in the "VRayDiffuseFilter"-RenderElement, or realy the whole computed diffuse?
      If it has to return the whole diffuse.. then, what's the difference between "getDiffuse" and "eval" with the FBRDF_DIFFUSE flag?
      I call the shade() function, but on the backside of my objects that is not illuminated by any light the beauty-RGB is still black... when I do the same with a VRay Material it is light gray (because of the GI)..
      Aya~
        Yes, it should return just the diffuse filter color for the surface.
        Do you mean back side like the side that is in shadow from other lights, or the back view of a single surface (on the reverse side of the normal)?
          I made a image to show you what I mean
          My Shader isn't reacting to GI at all
            Change the traceForward method like this, and it should work:
            Code:
            void MyBaseBSDF::traceForward(VRayContext &rc, int doDiffuse) {
            	BRDFSampler::traceForward(rc, doDiffuse);
            	if (doDiffuse) rc.mtlresult.color+=rc.evalDiffuse()*diffuse_color;
              Here is also attached a version of the VRayBlinn material example with added diffuse component and transparency.
                Hey, thanks a lot
                But I can't download it, because I don't have the permission for it
                  Email me to vlado@chaosgroup.com and I'll send it.
                    (Could you delete the post with my mail adress when you got it? )
                      Yep, I just replied to your email, apologies for the delay.
                        Thanks a lot~ it's working now
