Hemispherical textures and
  • Hemispherical textures and
    How do you apply these hemispherical textures into Vray for Maya's environment slot? I played around with the UV mapping settings and it doesn't fit right and there's no option for "equirectangula", "hemispherical" etc.
    http://www.cgtextures.com/textures.php?t=browse&q=23740
    Thanks.
    Maya 2020/2022
    Win 10x64
    Vray 5
    Apply a VRayPlaceEnvTex projection node to the texture and choose the "spherical" mapping type.
      Hi Vlado, I have tried this but it still does not look correct. Please see the attached image. It is in "Spherical" mode but it is pinched. I'm not sure what to do...
      Thank you.
      Maya 2020/2022
      Win 10x64
      Vray 5
        My question : it is normal that the VRayPlaceEnvTex have just 2 rotations (Horizontal and vertical), but not 3 rotations (X, Y and Z, like the env_sphere) ?
        I can't get a nice placement with this node :/.
        www.deex.info
          I just can't do this I'm going to cry!
          Can anyone please post a simple scene with one of these textures setup in the environment slot?
          I just cant get it right.
          Thank you.
          Maya 2020/2022
          Win 10x64
          Vray 5
            hey man,
            u want to use a "180 degree" image into a "360 degree" placement.
            when i understand u right?
            a way is to mirror the skypan in photoshop or fusion or so.
            then u have a double height image with smooth horizon and u get a 360degree image!
            this works for me.
            cheers
            Vray 3.5, Win10
            www.3dcompani.com
              thanks for the reply, these are 360* images "horizontally" but you're right I don't think they truly are 360* images.
              Do you mean you double the images height in photoshop and it should appear correctly in Maya/Vray/mental ray etc?
              Maya 2020/2022
              Win 10x64
              Vray 5
                u´re right man.
                these are only horizontal 360*, vertical 180* - a dome format.
                to make 360x360* make a black empty pic in double hight and paste in the panorama twice and mirror the lower one vertical.
                u see that I made an overlap for a smoothe horizon, and the black area at buttom must beleave because of "perfekt" double size in hight is nessesary...
                hope this helps..
                grrr...i see that i dont have rights for attachments..sorry
                Vray 3.5, Win10
                www.3dcompani.com
                  Hi thanks Kompozer I have got it working now.
                  However is it possible, Vray devs, to have this visible in the viewport somehow? Like the IBL node in mental ray? It will make placing these skies much easier than render, tweak, render, tweak etc...
                  Thanks!
                  Maya 2020/2022
                  Win 10x64
                  Vray 5
                    Yes, this is noted as a feature request.
