Forum Privileges HELP Vlado???
  • Forum Privileges HELP Vlado???
    Vlado,
    My account seems to have been partially disabled. I can not post in the regular forums.
    Username: toddmcm
    I own several licenses of Vray and need help ASAP.
    Since I've got you, I've been working on an animation that is a static camera with animated objects. I can not get a flicker free animation.
    Using 1.5 SP3 with the procedure documented in this thread here. (I've tried both ways)
    http://www.chaosgroup.com/forums/vbu...ation+settings
    However, as you can see I'm still getting flickering. Any suggestions?
    Full Res Quicktime Video Clip HERE it is 66MB download
    http://toddaveryphoto.com/hostedvids...mation%201.mov
    THANK YOU,
    Todd
    http://www.dev-res.com
    Well, think I got the flicker under control. Rendering now but the last one came out nicely.
    I used a material from a website without really going through it. The main material in the scene was using interpolation. Got rid of it and now everything is fine, changed the reflections quite a bit but it's fine for this purpose.
    Still need access to the regular forums when you get a chance.
    Thanks!
      For the forum access, please email us to vray@chaosgroup.com and we'll sort it out.
