Loading textures from HDD rather than RAM?
  • Loading textures from HDD rather than RAM?
    I am rendering a scene with a lot of big textures and in the end I run out of ram and it doesn't render these textures. Is there a way to do like with mental ray, use textures from hard drive rather than ram?
    is your bitmap pager turned on in your max preferences?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      I tried it on,off. I don't see a difference. If i turn it on, max uses only 100mb of ram but still spews out the error of lack of ram.
        This will probably not help you in the short run, but you should switch to a 64bit OS. That will basically solve your memory problems.
