setting vray separate render channels via maxscript
  • #16
    ok my script is still usefull to be sure to remove escape chars from the path.
    After that, it's also needed to "give" a bitmap to vray output_splitbitmap value to make it work.
    finally the solution came from here :
    http://forums.chaosgroup.com/showthr..._splitfilename
    Many thanks for sushidelic for that tip.
    note : it seems that the bitmap don't have to be into the same final peth than the desired one. It's just to "activate" Vray on this stuff.
    Jérôme Prévost.
    SolidRocks, the V-Ray Wizard.
    http://solidrocks.subburb.com
