Vray sp4 loading old setting problem
  • Vray sp4 loading old setting problem
    Hallo,
    I purcased Vray for 3DSMAX last week, today I install it, but I have immediatly a problem.
    I tried the Trial version of SP2, to learn how to use it and check before buy it, I download lot of scene from site tutorial like Evermotion, to explore it and learn about setting the engine, and I saved some scene to use it as a base for some future project with the buyed licence.
    I uninstalled the trial version and installed the SP4 following the instruction in your mail and using the dongle.
    Unfortunatly as soon i try to open the scene (olso the mine saveed and the downloaded from Evermotion tutorial) Vray SP4 not read the setting of the render, all is off GI and else.
    someone kow how can I resolve this problem.
    This will happen if the scenes were saved with the demo version of V-Ray; it will not happen for scenes saved with the commercial version. One work-around would be to install the demo, save the settings as a preset, and then load that preset with the commercial version.
      Really Thanks for the trick Vlado
        Seems that something not work, Preset loading not work or I'm not able to use it, I create some preset and I tried to load it, following the Vray help file, but nothing change on the setting of the engine.
        Someone can help me pls
