Difference between batch render and single frame render?
  • Difference between batch render and single frame render?
    I use Maya 2010 and V-Ray on OS X (10.6.3)
    I have a material with an image sequence set up as opacity map. I use another image for diffuse color, on a different UV set.
    Whenever I render a single frame it looks as it should be. When I batch render it, the image appears in a different place, as if the UV-set is ignored.
    (Even though I have an official VRay license I can't post in the appropriate forum... that's why i post it here.)
