Zbrush -> Maya with Vray
  • Zbrush -> Maya with Vray
    Okay guys, I'll start with versions first as I am really confused and there is a lot of old info that have been overlapped out in the forums. I want to know if this combination would work before making more purchases. Let us assume that the OS is Windows7 for this situation.
    Maya 2010 + Vray V1.5 and Zbrush 4.0 + Multi Map Exporter.
    What are the ideal settings to get a proper displacement working? Can it be done? Please share your workflow.
    Thanks guys.
    I don't use multimap but I've tested various settings, and 16bit with the alphadepthfactor in alpha gain and negative hall adf in alpha offset works.
