vray rt gpu time depended seed
  • vray rt gpu time depended seed
    hello
    i use vray at work - my boss owns the licenses and i dont wanna bother him with the logins - so i have to write in this area.. would be nice if you maybe can "unlock" me..
    the rtAnimation script gives good results on the gpu - but it would be nice if you could implement the seed option. As we have to live with the noise, at least it can be used to give a nice film grain effect - if time dependent.
    if someone wants to try - using the noise directly looks always just wrong or digital - the trick is to blow up the image in post by ~300%, apply a strong 1px sharpen filter and scale it down again - this does the trick (at least judging from the stills).
    i still hope vray uses some max native seed that is exposed in maxscript - but i guess that would be to nice to be true. (tried the "seed" command already - no luck)
    i know rt is right now not intended to be a production renderer - but its just too fast with a good gpu to be ignored.
    Thanks for the pointer; completely missed this one - we will definitely add support for the time-(in)dependent the option.
    For the forum access - please email us to vray@chaosgroup.com and we'll sort it out.
