Animations with Bongo
  • Animations with Bongo
    Is it posible to render animation using Bongo with Vray?
    Also can you setup a network rendering job to decrease rendering time?
    Kreten
    Hi Kreten,
    here what I found out from the log file:
    >> Done as of 02/27/06 (Beta 11)
    >> -- Rhino animation supported again (Bongo may work too but not
    >> supported)
    Here Bongo works fine with V-Ray.
    >> V-Ray for Rhino 1.5 version wishes:
    >> - Add Distributed Rendering
    Regards,
    Michael
      I think for network rendering there is a McNeel plugin on the way that takes care of that(the Farm or something like that?)
      , I'm not sure if VRay for Rhino would be compatible with it or not, but we'll definately be paying attention to it
      As Michael showed, Distributed Rendering, however, will definately not be a part of version 1.0 though.
      Joe Bacigalupa
      Developer
      Chaos Group
        "Distributed Rendering" - multiple CPUs working on same image or...?
        So, can we expect it in version 1.5 of Vray for Rhino?
          Yes, DR is multiple CPUs working on the same image at one time. It is on our wishlist for 1.5 - so if it is possible we will be adding it.
          Joe Bacigalupa
          Developer
          Chaos Group
            Dont say if its posibble...the goal is always to cut down rendering time with rendering softwares
              ok then, I'll do whatever I have to do to get it in there
              Joe Bacigalupa
              Developer
              Chaos Group
                Joeb, your THE MAN!
