rcm mapping
  • rcm mapping
    hi
    i can't seem to access the mapping widget (the thingy that adjusts postioning etc of the map on the geometry) in rcm rhino, i had brazil demo installed and i uninstalled it, have i broken the rcm, is this a rhino forum question or is it a vray problem, anyone have the same problem. this widget was working up until recently. anyone have any suggestion as to how i can fix this.
    neil
    rcm mapping
    Best you deinstall VfR and install it again. RCM will be installed per VfR.
      rcm mapping
      Yes it is best to uninstall and reinstall VfR. I still need to speak with them about having our plugins coexist using RCM. Its difficult since RCM is still under development. They should "technically" play well together - but if your experiancing these problems they must not be.
      Joe Bacigalupa
      Developer
      Chaos Group
        rcm mapping
        i've noticed that my RCM crashes now on boot up, but in your defense im running SR-4 which is compliant to some other plugins I am using that are not currently SR-5 compliant. lol what a mess...
          rcm mapping
          Are you sure its RCM causing the crash? If your basing that on the RCM crash dump message box- it may not actually be related to RCM. That crash dump dialog will pop up whenever a crash of any kind happens in Rhino while RCM is loaded. The message box just means that RCM is collecting information at the time of the crash and forming a dump file from it. So its possible the crash could be V-Ray for Rhino related, or some other plugin crashing, or it could be RCM as well. Let me know if I can be of any help tracking this down.
          Joe Bacigalupa
          Developer
          Chaos Group
            rcm mapping
            this is the message box i recieve.
            Rhino 3.0 CVRayForRhinoPlugIn::OnLoadPlugIn
            Failed to read registry for RCM status -- RCM mapping channels will be unavailable.
            to me it appears that RCM is not installed, or that would be my guess. I will reinstall and I would bet that fixes the problem.
              rcm mapping
              yup it couldnt find C:\windows\system32\RCM.dll
              why that happened i have no clue.
                rcm mapping
                Is everything ok at this time? Did you recently uninstall or install any other plugins?
                Joe Bacigalupa
                Developer
                Chaos Group
                  rcm mapping
                  Yeah everything is fine now. No I havent reinstalled or installed anything new.
