problem!
  • problem!
    Hi,guys this is my last work - high end audio system.I wish to apply some logos on front panels,but i did'nt know how? Is there Vray option like Flamingo's decals?
    P.S. i use vfr3
    Re: problem!
    Decals works fine. The workflow is:
    * create at your basic material an extra diffuse layer for decal
    * set transparency color white (this makes, that the diffuse layer is transparent around the decal)
    * set a transparency map and disable tile at the texture UI (so the texture will not repeat)
    * if you like set a diffuse color map
    You can use for example a planar mapping for the decal. Set diffuse color and transparency map at the same mapping channel of the planar mapping widget.
