Problem with shadow rendering
  • Problem with shadow rendering
    I have a model where I've used the exterior settings from the tutorial, but when I change the resolution or check " override viewport" the sun parameters from SketchUp disappear. I'm sure I unchecked " override sun parameters". Have any of you experience similar problems, or know what I might be doing wrong?
    Re: Problem with shadow rendering
    You do not want to uncheck "override sun paramters". In VfS there is no way, at the current time, to manually position a V-Ray Sun Light. We automatically use Sketchup's sun system. So when you uncheck that box you are basically just making it so you can't change the V-Ray specific sun params that are visible in the texture editor.
    Joe Bacigalupa
    Developer
    Chaos Group
