Materials dilema....
  • Materials dilema....
    Hi everybody have a question......its posible to use vray materials for 3DSmax in Vray For Rhino??....if not, there is a way to do it??
    Sorry my english.
    (In Spanish: Hola a todos, queria preguntaros si es posible utilizar materiales de Vray para 3DS Max en Vray para Rhino, y si no es asi, existe alguna manera de lograrlo??)
    Bye, thanks.
    Oscar.
    Re: Materials dilema....
    Hi Oscar,
    maybe you can use the new material editor?
    I did not tryout myself, but i think thats the way it works.
    greetings
    Jonas
      No you can't use vray materials made in max directly in vfr. However we did release a material converter which works from max to export those materials. So if you have max and vfMax then you can move your materials over.
        Hi ...
        i have the same problem...
        i have Rhino and now try to make renders in vray plugin
        but how to make .mat to vismat, becoast i have no 3DSMAX,
        and i never will have it....
        so what shuld i do....
        1. buy new 3DSMAX
        or
        2. put the vray render to recycle bin
        thx
        (why shuld i use vray render for rhino if i ned a 3DSMAX to convert mat. files to .vismat - i thing is better buy 3DSMAX only then both (vray for rhino + 3dsmax)
        so for what is the product if i must buy a 3DMAX to have materials,
        sorry but render without materials is basic the same like speedy car without gas )
        or it is a joke?
          You create your own vismat materials right in the plug-in, or in the material editor.
          You can import materials that already come with VrayforRhino, also. Right-click on "scene materials" in the material editor.
          Do you have the Vray Instruction Manual? It's in the download area. So are a bunch of user's materials that you can download for free.
            Hi
            txh for quick answer,...
            i know that i can make my own material in MatEditor,
            but i still try looking for program wiht more material library in basic...
            its nothing against vfr !!!, but the problem is me...! and my time.
            But i still thing, that Vray is one of the most best renders :-[
            bye, have nice time, and sorry for my english
