displacement problem
Re: displacement problem
McNeel's Displacement does not work with V-Ray. We have our own displacement function which you can find under Maps in the vray material editor. You can set it up just like you would a bump or another texture. If for some reason you really want to use mcneel's displacement you will have to use the ExtractDisplacedMesh command which will produce the displaced mesh (not nurbs), but this will be more memory intensive.Damien Alomar<br />Generally Cool Dude
Originally posted by RVallieres
In the texture editor,under bitmap you should have a number 1 or more in the modifier.
Renee
//Heiko
