DR. where to start ?
  • DR. where to start ?
    well, I would like to test the DR, but where do I start it ?
    thanks.
    Re: DR. where to start ?
    Under our System tab in our options you can enable DR and choose which machines to use. You can refer to servers by their computer name or by IP address. You will need to have our DR Spawner running on those other machines - if you installed it on the machine it should be in Program Files\ASGvis\Render Slave\DRSpawner.exe
    There are some issues right now with Sun/Sky when used with DR - just as a warning. But we should have a service release out by the end of September - early October that will clear up that bug.
    Joe Bacigalupa
    Developer
    Chaos Group
      Also check out the end of the V-Ray training manual...there is a section that goes through DR setup
        tnx very much, sorry for the stupid question, but I was trying to find it on the rhino 3 version.
        LOL
          Not a problem, no stupid questions here - but the options are pretty much all the same between VfR3 and VfR4
          Joe Bacigalupa
          Developer
          Chaos Group
            does DR. works on VfR3 ?
            I could find it on Vfr4 but not on 3, this is really bad because I need to update rhino to 4 version.
              It works on VfR3 SR1, DR is a new feature and the original release of VfR3 does not have it. You do not need to upgrade to VfR4.
              You should be able to download VfR3 SR1 from our downloads section. If you have any problem getting it, or using your serial number, go to the support center and log a ticket or email support@asgvis.com.
              Joe Bacigalupa
              Developer
              Chaos Group
