Interior rendering question
  • Interior rendering question
    Hello
    I am currently testing interior rendering with different options, I will soon post my wip and renderings with differnet settings as a benchmark..
    In the meantime I have been thru a lot of interior tutorials, my question is:
    If you have a directional light coming thru the windows, why do you have to put rectangular lights in the windows as well?
    Re: Interior rendering question
    Rectangular lights are a must? I think no. This lights are good to get direct raytraced light instead the GI env light only. The user can choose between "portal mode" that provide a raytrace light based on the colors from emitters/sky/HDRI behind or the standard rect lights.
    Imortant: try to avoid glass in windows (windows glass is invisible from inside most). If glass is used, try glass without refraction layer to keep the calculations simple. If refraction layer is a must, set "affect shadow".
      ok thats what I did no rectangular lights in the window, just directinal, no glass..
      thank you
      I will post render soon
        Here are my options - Hi Resolution I think..
          my lights
            couple of renders..
            This is an evermotion interior rebuilt in Rhino 4
            can someone explain what the radius does in the directional light?
            thank you
            critics help and suggestions very very welcomed
              ... radius set the size of the "sun" disk. Try a value like 0.05 - if I remember me right, the shadows should be light blury now.
              You links can't be posted as image. Also it seems to be a login necessary. I use photobucket.com to post images here.
                Hi Micha
                do you say you can't see my images? Because I see them.. :'(
                  I updaed my images hope you can all see them...
                  her is one of my last render with the radius of the directional light at 0.05 as Micha suggested
