problem with texture
  • problem with texture
    hello!
    i have a problem with a texture on my model.
    i had modeled a objekt in alias studiotools. now i want to render it in vray for rhino.
    i want to bring up a texture on different surfaces but must like one surface. so the problem is that the texture has different scales on on each surface.
    how can i fix this problem? is it a problem from the surface or the texture?
    greetings!
    peter
    Re: problem with texture
    There's no easy solution with this I don't think. Basically the default surface mapping is broken up, and it doesn't look like a surface that is easily mapped with the tools that rhino has. You could unwrap the UVs and then rebuild them to fit the map, but there's no way to do that directly in Rhino (ie it will have to be done through another software). The other option is to rebuild the surface in Rhino so it has the correct UV information to map the texture. Depending on how complicated the surface is that may be quick or very time consuming.
