Black dots, smb help
  • Black dots, smb help
    I'm the new man n' still trying...
    The prob is when I render my room, in the conner of the room alway hav some black dots...I don't know what happen
    It's because my setting or light or my material, any body help, plz
    By the way, can any body send me some file setting for a good render, plz. I'm not good in Eng >>> I'm so hardly using The manual
    Re: Black dots, smb help
    Do you have an Image?
      This is my prob, plz help me
        Look for Irradiance map setting in your render options! ;D
          Yea, post your irradiance map settings b/c thats what at fault on this one.
          In the mean time, there are two things you should check. The first is Adaptive Amount in the QMC Sampler. If this is at 1, then lower it to .9 or .85. Having this setting at one has been know to cause some artifacts with interior shots like this. The second thing is that your irrandiance map looks a little too dense. If you've got your min rate it at -2 or -3 try kicking it back to -4 or -5. Leave your max rate where it is (thats going to be the one determining the quality). Sometimes having too little adaptation in your irradiance mapping can cause more of these splotches to show up.
            I try to put Adaptive Amount to .85 and the min rate in irradiance map t0 -5, it's great now, thank you very much. I love you job ;D
              Bloodtide, How long did you render prewious scene , with thouse settings (just for statistic) ?
