Settings for default camera: parallel projection!
  • Settings for default camera: parallel projection!
    Hi Everybody.
    I need to render some elevations, so I need a parallel projected view. already checked the posts about it but to increase the focal length is not working for me. when I tried the default camera my render turned out to be completely white. so if someone can share settings for very simple elevations renderings with the default camera , I would be most thankful...deadline is almost here.
    (sorry about this very same post in the "general section")
    Re: Settings for default camera: parallel projection!
    Set your Field of View in Sketchup to 1 degree. It's not a true elevation, but is very close. Good luck.
