Failed Loading option files
  • Failed Loading option files
    Hi I was trying to load a downloaded .visopt file but a error uploading the file message appears, does anybody know what may happened or what I can can do to load it correctly, thank you very much.
    Re: Failed Loading option files
    If you are using an older version of VfR and the visopt was made with a newer version, then the visopt will not be able to load. Backward compatibility were are fine with (using an older visopt in a newer version), but forward compatibility takes more work. This is something we are trying to remedy with future versions.
