sun and light problems
  • sun and light problems
    hi, i met one big problem of the sun setting and light setting in the vray, whatever change i gave to the sun and light setting, they didn't change anything in the result of vray rendering, the parametres i gave is as shown in the attached image, pls help!!!many many thanks in advance
    Re: sun and light problems
    hi, maybe my poor english didnt make some sense,or maybe its a too easy question here? but i really appreciate if anyone can explain me the reason why the sun and lights didnt work in my cases. many thanks.
      * disable "default lights" helps to avoid the additional sun
      * if lights show no effect, than try a higher intensity - most the physical cam is the reason, because the exposure is adjusted for bright daylight
