Hi all,
The image frame buffer always produces the desired result but when I need to use the VRImage, after extracting it into photoshop, it doesn't look as it should if I were to use the Frame Buffer even though the settings have not been changed. Is there a way to get the VRImage to produce the same output as Frame buffer? Or is there a setting that I need to change if I'm using the VRImage?
Cheers,
Sando
Cheers,
Sando
