I'm having trouble getting a gradient displacement map to work correctly. When I apply the map, the result has bizarre stripes or ripples in the displaced geometry. I'm not sure if the problem is the gradient jpeg file or vray's interpretation of it. In any event, if someone knows how to fix the problem, that would be great. The images below show the files I used, as well as the desired result. I'm also attaching a .zip with all of the files included, in case you want to replicate the problem.
Zip File:
http://www.studio-office.com/ASGVIS/WOBBLE.zip
Desired Result (variable orientation in glass at left):
Rendering:
Displacement Map:
Zip File:
Rendering:
Displacement Map:
