It you are using the two together, you will most likely have to change the intensity of one or the other. If you're using the physical camera, you'll likely have to increase the multiplier on the hdri to get it to be bright enough to appear in the final rendering. If you're just using the regular camera, then the sky might be really bright, so I'd decrease the Intensity within the sky settings...you might have to go as low as .03
