Yacht Render
Re: Yacht Render
It's not bad so it's hard to make it better. May be that's the way - make it less perfect (reflections, colors). BTW the light tubes are gorgeus, how did you do tham? (I'm supposed to make some interior lamp for exams
Re: Yacht Render
LANCZOS is a sharpen filter and this will cause more visible aliasing. Most I use no filter or area 1.2 .. 1.5 (light blur). I belive, strong sharpness and high antialiasing are not possible or not easy to get.
Also you could render a bigger image size with less strong noisethreshold and downesize the image later - maybe this will bring a better antialiasing, dependent from the downscale method (I don't tested it, but would try it, if I need it ).www.simulacrum.de - visualization for designer and architects
