Loading Materials
  • Loading Materials
    I tend to use the same materials in much of my work. Is it possible to load a defined group of materials in one go (even at launch) rather than one at a time?
    Thanks
    Jack
    Re: Loading Materials
    Not direct, but if you have all materials assigned one by one to objects in a rhino file, than you can copy&paste all objects from the Rhino file to an other. If you undo the copy process, the objects are gone, but the materials stay at the material editor. I go this way often to copy materials from one project file to an other.
      Thanks Micha,
      Given me an idea. I guess I can set up a special .3dm file, say called 'Palette.3dm' with each commonly used material in it. Them simply import this and then, as the imported bits will be highlighted, press 'delete' - the materials will all be there. Might even try to script this (have to ask how on the Rhino forum), even try a button!
      Thanks
      Jack
        It's quite easy without scripting - import file -> undo -> ready.
          In fact its easier than all of that because there's a command for this... visLoadDirectoryVismat...just put all the materials you want in one folder and write a macro...Done
            wow - thanks
