Why is this happening to me?
  • Why is this happening to me?
    What should cause this result? no shadow in the billboards, splotches in a no reflective gray diffuse material, and some weird metal results?
    it has a sun and a physical camera + medium quality vray express settings.
    www.leobonilla.com
    Re: Why is this happening to me?
    i incremented the quality setting to high, a it reduced the problem a lot, still don't know witch setting is causing this.
    www.leobonilla.com
      Are you using the V-Ray Sun?
        Also check if you have Reflective caustic enable on Indirect Illumination rollout. Some time produce that kind of issue.
          yes, and i dont have any caustics calculation setting
          www.leobonilla.com
