Newbie Here need Help?
  • Newbie Here need Help?
    good pm guys, i'm a newbie in using vray for sketchup, i've rendered a few scenes before, no problems whatsoever, but just now i got stumped with this, i've used an image from the net as texture:
    here's the scene:
    and this is what i ended up with:
    - a lot of stuffs missing right?, the floor is the same as the wall, the green lines ended up in white-ish, the images on the wall went missing too, the stair type thing on the wall also ended up in a white-ish finish?
    anyone here knows why?
    thanks in advance for those who can give hints or ideas on why things got lost in the render. ;D
    Re: Newbie Here need Help?
    What version of VfSU do you use?
    Have you applied materials to the outside of groups/components? (You should never do that - all materials should be applied to faces.)
      If I remember correctly, sometimes you have to right click and export the jpegs from your materials out of sketchup onto your hard drive so that Vray can 'see' the file. I think it happens when you download stuff from Google warehouse, but I may be wrong. You can check it out in the vray materials tree to see if it is finding the diffuse maps ok.
        hhmm 'this seems to be my problem, already tweaked my scene awhile go, got all materials and jpegs to show already, what i did was all my walls are in groups (i think?) and had applied materials to them (ended up with them white walls), so i explode all walls erased made new ones then shazam! hehe all good, thanks sirs/,mam for the help
        gotta explore this vray thing more ;D
