Specular
  • Specular
    When i downloaded max materials, I always use the bump and displacement maps, but the specular were can I use it? It can be used or not?
    www.leobonilla.com
    Re: Specular
    You should use the specular texture on the reflection layer under the fresnel mapping. Click on the "m' near the white color and put the specular texture there.
    ssaludos Leo
    El specular se usa para controlar que areas deben tener refleccion y en que areas no. Para eso debes poner el mapa en el efecto fresnel, en el mapping del color blanco.
      Re: Specular
      I prefer to use the Specular as Filter in REflcetion map, maybe changing a little bit the multiplier to get the right result.
      Am I wrong?
      Riccardo
