material texture question
  • material texture question
    I am new to v-ray for sketch up and have been experimenting with material. By importing materials from asgvis.com I have tried to edit the materials in su in the "materials" - "texture" box. On screen the material shows the textured image referenced to the correct size, but when I try and render the material it does not show any texture. Do you have to save your edits to scale materials to the correct size before rendering? Other materials I have used adjust fine through editing textures and sizes. Any help would be great thanks.
    0
    1
    0%
    0
    1
    0%
    0
    Re: material texture question
    Did you applied the material on the outside/directly on group or component ?
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
      just on an individual component. Does this make a difference? Im thinking it does with your response...Thanks
        The difference is most likely what you're experiencing.
        You need to apply the material directly on the face/geometry. Also remove the material that applied to the component itself (apply the default material on it).
        www.Top3Dstudio.com
        SU 8
        VfS 1.48.89
        Win 7 64-bit
