Can't browse for bump map
  • Can't browse for bump map
    Vray will not allow me to browse for my grayscale bump map.
    I click the 'm' next to bump, under 'Maps', within my diffuse layer. Texture Editor opens up and I then select 'TexBitmap'.
    When I click 'm' next to Color Offset, Texture Editor opens again and I'm seem to be stuck in a loop where I cannot browse for my file but only select the vray preset maps.
    Am I doing something wrong?
    Thanks.
    Re: Can't browse for bump map
    The slot for adding a bitmap is waaaaay down in the bottom right of the material editor in the new VfSU UI, you might have to scroll down to see it.
    SU 2018 + VfSU 4.0
      That was so helpful, thank you! I could not find that anywhere!
      :thumbsup:
