need help on material bump
  • need help on material bump
    im trying the new vray now. im having problem on the bump. i already put the bump map. but when i render, the bump doest show on the material. i even try to put a hi no. on the multiplier but no effect all all. can anybody teach me the correct way on bumping a material.
    Re: need help on material bump
    Select the material you want to add a bump to, in the MAPS heading tick the 'Bump' box, then click on the 'M' next to it to open up the texture editor. Select "TexBitmp" from the dropdown menu on the left, then use the scrollbar on the right hand of the screen to scroll down to the very bottom right and click the 3 dots, then browse to your bump map file. Then press ok, then it will close the texture editor - you can then click preview in the material editor and it will show your new applied bump.
      thanks edonk, but thats exactly what i did, maybe there is something wrong with the demo product that i installed. same with displacement, i coudn't make it work.
        The geometry with the displacement should be grouped alone.
          i alredy figure it out. The material that i was bumping has .75 hilight glossiness and .75 reflection glossines, when i put them back to 1, the bump on my material shows. but everytime i decrease the reflection glossiness even only to .95 the bump doest show. Any idea? is this Bug or something?
