Hi all,
I have an issue with polysurface mapping.
If I create a NURBS cube - Explode it - Select one of the surface and then try to change setting in object properties in Texture Mapping/Custom/General/Projection/Surface
I can't because the settings are disabled..
I guess it's because the surface was a part of a solid, but I am wondering if there is a way to reset all mapping properties of my surface to be able to change mapping properties.
thanks
thanks
